Body Lift Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big pappa b, Apr 27, 2004.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    So I have a 2" body lift I need to install..or remove my power brake booster every time I need to remove my drivers side valve cover /forums/images/graemlins/tongue.gif
    I know I will have the issue of the gas tank fill tube to lengthen and cutting the bottom of my fan shroud to clear the fan. Has anyone done a 2" lift and what problems did you have?? I believe all my hoses and wiring is long enough to accomodate a 2" lift.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I put a 2" body lift on my burb and the only thing i did with mine is lengthen the auto tranny linkage, and cut and lengthen my fan shroud. I didn't have to replace my filler tube and the rubber hose was ok.
  3. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    The only problem that I had was one of my bolts would not come out. I had to cut the head of it off and hit it thourgh the other way. I have a diesel and I had no problem with wires, brake lines, filler neck, or trans. lines.
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    dont forget steering, i put in a 3" in mine and a ORD 1" in SF87K5s and both required the tranny linkage be adjusted and on mine i had to melt the nylon "bolts" in the steering colum to stecth it out, if you do that you need to replace them with something thats strong enough to collapse if your body hits the steering wheel hard but will keep it from seperating while flexing /forums/images/graemlins/peace.gif
  5. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    My fan shroud is 2 pieces, connected with staples in the center where the seam is. I took the staples out and used bolts and pipe to make 3 inch spacers (3 inch body lift) rather than cutting off the bottom of the shroud.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Your still gonna have to trim the lower part of the shroud. The shroud fits in the lower part of the rad support, which goes up with the body. You need to trim it so it will go past it. I have also done a couple 1,2, and 3" body lifts. beside the linkage adjustments and steering shaft issues(3 inch only) the rest was no prob.
  7. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    So what should be required to fix after a 1" body lift?
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I think that part has to do with different year of rig. Cause on my 75, the lower part of the fan shroud fits into clips on the EDGE of the lower core support. I didn't have to trim the lower portion of my fan shroud at all. I just removed those clips so the shroud would pas by the core support and made new mounts for the side of the shroud at the core support.
  9. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Second that question /forums/images/graemlins/confused.gif
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    With a 1" body lift, about the only thing to fix is the fan shroud.
  11. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Sweet, I am looking at the ORD set. How much work is involved? ie. A full days work w/ 2 guys working?
  12. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    fan shroud, That was all I had to fix with a 1"
  13. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I installed my 2" in half a day by myself.
  14. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Are the instructions good enough for a first timer to do the job?
  15. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeppers, when I did mine, I had never done one before, so it was somewhat painless. Only real problem you will have is if you run into any rusty/stuck bolts.
  16. barryb
    barryb Registered Member
    Oct 15, 2003
    51
    Springfield MO
    did you guys leave the bumpers and make fill plates, leave it gapped or raise the bumpers?? im having trouble making up my mind ....
  17. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    When doing a body lift, it's a great time to make a custom bumper, because you can tie into the body mount bolts with the bumper, replacing part or all of the lift block with the bumper
  18. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    non of the above, i did custom bumpers /forums/images/graemlins/thumb.gif
  19. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I done a 1" body lift
    So I done a 1" fan spacer
    I'm getting ready to do a 1.5" body lift on the project truck so it will get the same treatment.
    I also had to adjust the tcase shifter but not the tranny shifter.
