body lift Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rix_Gotta_Blazer, Dec 15, 2001.
  1. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    Hollister, CA
    if a person is to put a 1" body lift on their Blazer, do they have to cut the radiator shroud and go through all the motions like a 3" body lift makes you do? and the same witha 2"? thanx.
    i liked this bumper sticker i saw, "real Americans DRIVE American"
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    Plano, TX
    With a 1", you will have to trim a little off the bottom of the fan shroud, usually. Check your clearance now. If you have more than an inch between the bottom of the fan and the shroud, you will be okay. But, you probably don't have that much clearance.
    Only other thing you will need to do is adjust your tranny linkage. No fabrication, just loosen a bolt, slide it down the shaft, and re-tighten the bolt.
    No other mods should be necessary.
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
