body lift question
Discussion in 'The Garage' started by Muddytazz, Aug 8, 2002.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    When doing a body lift, do you have to adjust the t-case linkage? I have a 203 in a 75 burb.
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Hi
    You can check out the write-upp I did on my page: www.espen88k5.alloffroad.com
    I disconected it while lifting, re-installed it and drove with it a couple of months before I used the adjustment treads on the rods to extend it 1/2 inch. It kept popping out of 4x4 high
  3. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    may have to lengthen it maybe.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Here is the thing that i don't get though. It looks to me after looking around that the t-case has nothing to do with a body lift. Only thing that I might see being a problem is the shift lever hitting the cut-out in the floor. Can someone explain to me what it is that I seem to be missing.
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I didn't have to adjust or lenghten my t-case linkage. I only have a 1" body lift though. /forums/images/icons/tongue.gif
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm only doing a 2" and I can't see how you would need to do any adjustments. If I'm missing something, please slap me in the face and show me the light.
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    You are correct, it is just a matter of the shifter rod hitting the cut out in the floor. can trim to make sure it still works if need be.
    Ken H.
  8. Espen88k5
    Feb 19, 2000
    981
    Norway
    Just one of those deals where you find out what you end upp with and work out the bugs afterwords. I remembered my Warn 3" had it mentioned in the instructions, and it involved cutting the floorboard to allow the shifterhandle to travel the needed lenght.
    Like I said before I solved my "pop-out of 4x4 high" issues by adjusting the treads on the rod between the transfer case and the shifter asembly. Took me a couple of tries though....
  9. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I believe that the 203 shifters are mounted to the tranny or t-case and the 208/241 shifters are mounted to the body, correct? This would be why some have had to adjust the linkage and some havent.
