body lift question.
Discussion in 'The Garage' started by 91k5NC, May 7, 2003.
  1. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    iv'e got a 3" body lift, do i need to extend the transmission likgage or what else would i need to extend thanks drew /forums/images/graemlins/thumb.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Yep tranny linkage needs to change. I don't know if they sell a part or not. I made one for my freinds truck. You also need to modify your fan shroud so the fan doesn't hit the bottom of it. It varies on what else can be to short keep an eye on all your libes and wiring under the hood and such.
    -Brian
  3. BiggerIsBetter
    BiggerIsBetter Registered Member
    Aug 9, 2002
    23
    Livermore, CA
    <font color="blue"> Fan shroud, tranny linkage, and gas filler hose. My kit from Performance Asseccories came with the 3 inch linkage to weld on to the existing tranny linkage. You have to cut the origininal in half and weld it in the middle. If you want to make it look nice then raise the front and rear bumpers and maybe some gap guards. When I installed my 3" body lift all the wires on the firewall had enough slack in them. </font>
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I don't have a Body lift but I think the t-case linkage may be affected also...
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    sounds like a good time to go ahead and install a trick floor-mounted shifter. /forums/images/graemlins/grin.gif
    j
  6. ccox7
    ccox7 Registered Member
    Jul 24, 2002
    69
    Bayou State
    Hello Drew , don,t forget to disconnect the tailgate torsion springs that are attached from the tailgate to the frame.They will need to come off before you can lift the body. I am in the process of lifting my 2wd 3 inches. Dont really know about that shifter linkage.
