body lift questions
Discussion in '1936-Present Suburban' started by DesertDueler, Dec 10, 2002.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Who has a body lift on their burb? How well does it work? and Does anyone do any heavy towing with a body lift. I want to make my burb bigger, but want it to still be able to tow a blazer.
    Dan
  2. Heavymetal
    Heavymetal 1/2 ton status Premium Member
    Mar 30, 2001
    936
    Oregon
    I have a 1 inch ORD lift on mine, and I have had zero problems with it. ORD makes their pucks with solid metal, not the hollow plastic I have seen with other makes. I am not sure how much difference a body lift would make in regards to towing since your towing from the frame down. Hope this helps./forums/images/graemlins/smile.gif
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i have a 2" and it's nice gives the sub a good stance, it already had a 4" anyway. /forums/images/graemlins/burb.gif
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I've got a 2" body and a 6" suspension and I tow with mine all the time without any problems /forums/images/graemlins/smile.gif
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Well with big drop hitchs you put alot of stress on the frame. I was wondering if anyone had any problems with that. For instance, I have to use a 12" drop hitch to tow m boat, and it clanks alot.
    Dan
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    i've got a 8" drop for pulling my dads boat with no problems, my dads burb has a custom made 16" drop easy lift hitch to pull his 35' travel trailer, been there for 8 yrs with no problems with sag, bending, stress or anything. It just all depends on HOW you tow and using common sense.
  7. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Does anyone know of a company that makes a 2" or 3" solid metal body lift? I saw a billet aluminum 3" lift awhile back but would prefer a 2". Thx
  8. muddysub
    Jun 23, 2001
    10,451
    489
    ORD makes a 1" aluminum but i've never seen an aluminum 2-3"
  9. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Why not take a 1" ORD lift and add a bunch of washers? YAAAHHHOOOOOO!!!! /forums/images/graemlins/1zhelp.gif
  10. Heavymetal
    Mar 30, 2001
    936
    Oregon
    You could buy 2 sets of ORD pucks and stack them. I would never recommend this with the plastic pocks, but the ORD pucks are a very tight fit to the bolts and they are metal.
  11. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    You've seen mine, 6" suspension, 2" body, with 38's. I tow a 2300lb car trailer with anything from my 3000lb Chevelle to other club members K5's. I don't have any complaints about the lift affecting tow capacity. The heaviest thing I've towed was a 1989 1 ton extended cab with a big block. I didn't have any lift back then, but I couldn't get over 50 mph becuse it would sway too much. I only us a tow ball (2 15/16?) with no sway control or load leveling hitch.
  12. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I JUST put a 3" body lift on mine...works great! The only things are that it transmits more vibration. You will feel the motor idling. No gripes though! REALLY easy to do, and my steering still feels as responsive. One recommendation, though...buy a Borgeson steering shaft.
  13. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Do you have picture with both the body & sup lift with those 36" hummer tires? I am currently running the 36" Hummer tires with my 4" HD Superlfit. I am also thinking of a 2" body lift, but would like to see what yours looks like.
    Also, does anyone have experience with any brand 2" poly pucks? This is what I was thinking of. Also, any brand positives/negatives?
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I bought my 2" body lift and new energy supression poly body mounts at 4WPW
  15. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    What did you like/not like about them? Did you get everything you needed in the kit?
  16. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    From what I understand, the 1" and 2" body lift kits are the same (minus the difference in puck size), the 3" kits have a little more pieces involved. On my 2" kit, everything I needed was in the kit, pucks, nuts, bolts, washers, etc. As far as the lengthening the auto shift column (weld in piece), I didn't want to cut and weld in the new piece, so I completely made a new, longer piece all together. Other than that, was happy, no problems with the kits. Only problem you will run into is possible rusty/seized body mount bolts, and you will have to drill 3 holes in the cargo area to hold the lift pucks, chevy didn't use bolts to mount those cushions, just sandwiched them in. Muddysub can atest to this, he didn't drill holes in his, just put the pucks in, ended up losing the pucks when you flex. Hope this helps.
    I do have some pics on my webshots if you wanna look. If you want more pics just lemme know and I can take some more /forums/images/graemlins/grin.gif
  17. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    I can get you one, just give me a little while...I have it in my profile, but it's all going on next week.
  18. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    BTW, for the pucks with no bolts...I just drilled about half an inch into the pucks and placed a bolt through the puck and the mount and put a nut on the end. It holds them together very well, and I haven't lost the pucks.
  19. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Well, O got my 38.5x 14.50/15 Sxs today!!!. Time for cutting I guess, unless I come up with the funds and time for a body lift.
    Dan
