Body lift steering problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, Apr 4, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I have a 1979 K5 Blazer and I am installing a 3" body lift.
    I have read many different theories on the steering correction. I am trying to loosen the entire column and I got the bolts inside the cab no problem but the two clamp nuts on the firwall are covered with undercoating. Does anyone know what size these two nuts are so I can hammer a socket on them. I left aircraft paint stipper on them all night and I have yet to go to the shop to see if it ate through the undercoating.
    I have also heard of people heating the plastic pins in the slip joint to extend the shaft, but I needed to adjust my column anyways. Any information on the problem or a cure would be greatly appreciated.
