Body Lift Time - Do's and don'ts
Discussion in '1936-Present Suburban' started by or2play, Oct 11, 2002.
  1. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Body Lift Time - Do\'s and don\'ts
    Got my body lift, am expecting the bushings very soon. So who's got some installation do's and don'ts. Its a 2 inch kit. Any shortcuts or tricks you guys found when you installed yours? Thanks a bunch.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Body Lift Time - Do\'s and don\'ts
    Big word of advice....TAKE YOUR TIME!!!
    Make sure all your wiring and fuel and tranny lines are out of the way, disconnect your shift linkage(might need to be lengthened) and start with the passenger side then to the drivers side....oh, make sure you melt the steering shaft plastic pins out. I do have a few pics on my webshots. Good luck.
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    [/ QUOTE ] OK! i don't EVEN see a point to this at all! all i did was loosten the 2 bolts at the fire wall and lift it, no heating no melting. my 2" went fine that way as did mudbogAD's 3". so sorry jeff but i gotta disagree with ya here.
    i can give you some actual advice though, there are 14 body mounts on a suburban, 10 have bolts throught them (GM engeneers at work there!) if you start at the back and go foreward, the 4th mount pair (in front of the rear axle) have no bolts, you might as well not put the pucks in them until you drill the floor and put bolts in, i lost a puck that was pinched in there today. oh and depending on how your engine runs the fan shroud is not a big deal, my motor runs colder than it should on average anyway so missing the bottom half of the shroud is not having any bad effects on me. but i will probably put it back in before next summer.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I mostly depends on how long your steering shaft is as to whether or not you need to do that.
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I didn't melt anything on mine either. Here's a link to my bodylift pics: Bodylift
