body lift with np208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big75jimmy, Mar 5, 2003.
  1. big75jimmy
    big75jimmy Registered Member
    Jun 26, 2001
    77
    Kirksville MO
    I have a 85 GMC with an np208 and I am putting a body lift on it and I want to know what do with the shifter after the body lift is installed.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I didnt have to do anything to the t-case shifter. I did weld the extention into the trans linkage, but the t-case didnt need any adjustment. BTW, I did a 2" BL
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I have a 3in and had to cut my rod and add in a drop of 3 inches.
    I never have gotten it adjusted right, it creeps out of 4hi when I get on the gas and the motor and tranny twist, but stays in 4low fine.
    Im gonna adjust it better if I ever get my tranny back from the shop.
    IMO mounting the shifter to the floor and going to the case was a bad idea on GMs part. Should have been mounted to the case like a 205.
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I installed a Precision Accessories 2" a month or so ago. The only thing I did was weld the extension on the trans linkage. Also, don't forget to take out your fan shroud & put in a spacer or something. I overheated my motor as my fan was bound & wouldn't even move.
    /forums/images/graemlins/thumb.gif
  5. big75jimmy
    Jun 26, 2001
    77
    Kirksville MO
    What if I just space the entire assembly down 3 inches? Has anyone ever done this?
