body lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Apr 22, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i want to gat a body lift, where is the cheapest place to get one
  2. freeforever
    freeforever 1/2 ton status
    Feb 21, 2001
    305
    Missoula, MT
    How high are you looking at going? you have to be a lil more spacific :) but a good place to Look is Summit cataloges or www.summitracing.com....they have it all. heck maby even
    J-C whitney.
    "A closed mouth gathers no foot."
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You sure about that because....you have to adjust your linkages on the tranny and t-case. Your bumbers sit lower and look stupid. Your steering shaft has to be extended. You're fan shroud won't line up right. The torque rods in the talgate may cause trouble. There's probably some various things I'm forgetting. The higher you go the bigger PIA it is. The body lift would be for you have a 6" suspension lift and to go higher.
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I got my 3" from Warns. They where allright and came with a pretty decent instruction manual.
    Dependent of how much salt your Blazer has seen installing a bodylift can be a weekend jobb or a 2 week jobb. I took some pictures while I was innstaling mine. They also show how I made brackets to raise the bumpers afterwords.
    They are at:
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
    [​IMG] If your not living on the edge, your taking upp to much space![​IMG]
