Body lift
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by wfahlgren, Dec 17, 2001.
  1. wfahlgren
    wfahlgren 1/2 ton status
    Dec 30, 2000
    157
    Northern California
    What are the pros and cons to body lifts? 2 Inch 3 Inch. A 3 inch body lift VS: a 2-4 inch suspension lift. Other than the cost?
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    The pro's of body lifts are that you can have more room for larger tires obviously, but besides that it keeps the center of gravity lower than if you did a suspension lift... The body lift will only raise the body off the frame.
    The suspension lift will raise the frame, engine, transmission, all the heavy stuff, which will make your rig more top heavy.
    Theres several different ways to obtain a suspension lift, in most all cases you will have aftermarket front springs with a different arch or spring rate to give the the added lift.
    For the rear you could have springs, blocks, or a shackle reversal... I'm not going to go in depth on each one, but it depends on what you are wanting to do with your truck, what kind of wheeling, etc. Are you going to be jumping it, hillclimbing, mud boggin', rock crawling and getting it twisted up? It all depends on what you're after.
    my 2 cents for ya.
    [REAL MEN DON"T CARE ABOUT GAS MILEAGE OR RAPID TIRE WEAR!]
    Ryan B.
  3. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    one thing ive always looked at with trucks with 3" body lifts is... what if it was in an accident and ONLY the body hit? it looks like TO ME that those super long body bolts would snap and your body would go flying...... someone please correct me if im wrong
    68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, dana44, 14 FF, <a target="_blank" href=http://communities.msn.com/68K10>http://communities.msn.com/68K10</a>
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    Jes,
    i went with a 2" body lift to put in onboard air tank and a larger gas tank(31gal) without having it hang too low. I am shooting for a total of 4". i am waiting for my 2" suspension lift. All i really needed was 1.5" of body lift but the 2" was cheaper. I would not go any higher than that. I've had no problems and it makes working on your truck/blazer a lot easier. i don't even have to open my hood up to change my sparkpluges[​IMG]
    my 2 centavos.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  5. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Also, with the body lift you either need to lower the radiator or the fan shroud. The fan will hit if you don't.
    FWIW, I am debating whether to go with a 4" suspension lift with a 1" body lift or a 6" suspension lift when I go to larger tires. I like the idea of the lower center of mass for a lot of reasons and I could then go to a low hump doghouse and gain a little bit of a better shot at my transfer case boot (because of the NV4500 I had to move the shifters back and the high hump is now kind of abrupt at the back; a low hump doghouse would fix that). The gaiting factor will be whether Skyjacker makes a 2" soft-ride rear spring or only makes a 4" as the shortest one. I want to do a shackle-flip along with the lift, so...
  6. 71GMC4x4
    71GMC4x4 Newbie
    Apr 1, 2002
    I have also heard that if you have a body lift, and you do alot of off roading(rough off roading) that eventually the lift blocks could break through your floorboards. That's just what I heard. Please let me know if I'm right or wrong.Thanks
  7. BlzrProne17
    BlzrProne17 Registered Member
    Nov 3, 2000
    27
    Wichita, Ks.
    That would make sense in a way. Your lifting the truck higher on those main points. I know a guy that had a "homemade" set of block consisting of hockey pucks. It's illegal by the way. Needless to say he saw some girls and stepped on it causing the blocks to shoot out and the body to land on his bueatiful 44" Boggers. He's got a good set of fender flares now. Lol. I'm going to take my truck and put a suspension lift on it due to the fact that I like the thought of my entire truck being lifted from the springs rather than those bolts. Do whatever makes you comfortable.
    Matt
