Body Lift
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by aksidentproan, Sep 16, 2002.
  1. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    I got my 2" body lift and have all the body bolts out. What's going to give me problems when I install this? Ive got a manual tranny. Thanks.
    Evan
  2. 71blaz
    71blaz Registered Member
    Aug 1, 2002
    86
    southwest colorado
    My 71 has a 1" body lift that came on it and tne problems that I have noticed, include the fan shroud is broken and
    does not fit anymore and someone had to butcher /forums/images/icons/frown.gif the drivers side inner fender so the steering shaft would fit. I am considering removing mine.
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Put the bolts back in one side and do the lift one side at a time. Leave the other sides bolts loose.
  4. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    You may have trouble with your clutch linkage (pedal to under hood arm). You may need to trim the trns tunnel @ transfer shifter to get all gears.If you have a stock front bumper you may need to bump it forward to clear the fenders.Get a longer gas filler hose, and watch the wire harness, and you should be alright. /forums/images/icons/smile.gif
  5. aksidentproan
    Dec 8, 2001
    477
    Maryland
    I got it on and I'll have to lengthen the clutch linkage rod and cut the gear shift hole in the floor a little bit bigger so it will go into 2nd. Other then that it was a very simple install. Thanks.
    Evan
