Body lift
Discussion in 'The Garage' started by 82GMCP/U, Mar 23, 2003.
  1. 82GMCP/U
    82GMCP/U Registered Member
    Feb 13, 2003
    37
    Lake George, NY
    If I take the 3" body lift out of my truck, will I have to change anything? It was there when I got it and don't want it there.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    other than the bolts that hold the body on. I would check the lower part of the steering column, sometimes people make these longer. and ck the fan shroud, I have seen people hack the bottom out so the fan still has room. Ck your fuel lines in the back by the tank, sometimes longer pieces are needed for lift and they might not work if lift is taken out. Thats all i can think of.
  3. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    if its automatic the shift rod going to the tranny might need cut off (3in) they need extended for the lift and if not shortened might hit tranny and not shift! just a thought /forums/images/graemlins/thumb.gif
  4. 82GMCP/U
    Feb 13, 2003
    37
    Lake George, NY
    Thanks for the heads up guys, I will look into all these things
