Body Lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Dec 30, 2000.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    what do yall think of body lifts?
    i want to add a 1 inch body lift to my 2 inch suspension lift.
    any thoughts?
    and how hard is it to install?
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  2. militaryblazer
    militaryblazer 1/2 ton status
    Nov 14, 2000
    235
    Azle, Tx
    I have the ORD 1" Body Lift not installed yet! From what I have heard with a 1" there is no modifications. I haven't installed mine yet cause it means I will have to cut on the bedliner to get to the bolts in the bed of the truck. The bedliner isn't very easy to cut either.
    '86 Military Blazer <font color=green><A target="_blank" HREF=http://www.geocities.com/m1009_86>http://www.geocities.com/m1009_86</A></font color=green>[​IMG]
  3. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    does it come with directions for installment?
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I installed a 3" on an old toyota truck I had, and vowed never to do it again.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  5. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    3 inch body lift has all the change and mods that have to be done, the 1 inch doesnt. is that correct?
    why did you vow never to do it again?
  6. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    They come with a step by step instruction for the specific model truck you ordered it for. Problems will be rustet stuck bolts, nuts that spinn inside the rustet out bodysuports , eyes filled with rust and undercoating from banging on them while on your sore back with the sore bleeding nuckles. They can be trying at times. .
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    You shouldn't have too much trouble with an 85, of course depending on the rust- use alot of WD -40[​IMG]. Install is pretty straigth forward. Don't forget to adjust the tranny and t-case linkages when you're done. I used a couple of 4x4 sections of wood on top of the jack to hold up each side of the body. One side at a time and you should be fine. It is a really good idea to change the body mounts while you're at it.
