Body Lifts : Good or Booty Fab ?
Discussion in 'The Garage' started by BrianDamage, Dec 4, 2004.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    Trying to think through my options on what I HOPE I can do to my Blazer next year. Hoping for 1 ton running gear and a 6 to 8 inch lift. Should I even consider a body lift at all ? I have heard good and bad about them..what do you think ? /forums/images/graemlins/dunno.gif
  2. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I'm thinking of just doing a 1". I don't think any higher is worth it IMO. /forums/images/graemlins/truck.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If you want too have some flex, I wouldn't go over a 6" spring. I much reather trim the fenders then do a body lift. I guess a 1" body lift would be okay, but I personally wouldn't do anything more. /forums/images/graemlins/whistling.gif
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    1" at the most, do your self a favor and /forums/images/graemlins/hack.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Body lifts are fine. I'd likely go 4+2 if I had it to do all over again.
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    [/ QUOTE ] I concur. Its what im running.
  7. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Pretty much what im shooting for as well. Body lifts are fine, to a point.
  8. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    i am running a 1" helps with clearance issues body to drivetrain!
  9. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I going to run an 1" BL, so I can clock my t-case.
  10. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I am running 6 and 3 with no problems.
  11. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    It all depends on why you want it. Are you just trying to make some extra room for tires? They are great for that purpose. If you are looking for a really clean looking truckwhere looks are important a, body lift probably isn't the way to do it if you don't want to spend the time making everything just right. I have a 3" body lift and cut my frame horns off and raised the bumpers 3" to match the body. I just can't stand that nasty 3" gap.
  12. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Had a four inch lift on my 90 Bronco I used to have. Wanted 35's so I went with a 3 inch body lift. I will never do that again. They are cheap and doing the actual install for the lift pieces, while not pleasant, wasn't too bad. But, moving around all the stuff under the hood, lengthening the shift rod, bending and relocating the transfer case lever, and all the other headaches wasn't worth it. Then on top of it all, I could really notice the difference in the ride. It just felt weird. If you do one, I'd stay with one inch tops.
  13. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    i ran a 3" BL on a 85 jeep grand wagoneer ( the big ones ) it was easy to put on and gave me the room i wanted but i wouldnt go that much ever again after the body lift i had twice as many creeks growns and other weird noises and even at times the roof would make a real loud pop when it got flexy but on the other hand i think a 1" would be fine on a chevy because i dont think the frames flex as much as the full size jeeps do
    willow
  14. bandit1
    bandit1 Registered Member
    Sep 17, 2004
    51
    Stockdale Texas
    I dont see why anyone wouldnt like a bodylift. Ive got a 3 inch on my '94 fullsize blazer. but thats all im running. I wouldnt put one on a tow rig though, cause i have to use a gooseneck hitch around the ranch. /forums/images/graemlins/k5.gif
  15. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    On a 91 GMC Suburban. Would a 1 inch body lift cause any linkage issues?
    Would it add to the "top heavy" feeling
  16. vervepipes
    vervepipes Registered Member
    Sep 25, 2004
    20
    Alberta, Canada
    i have a 3 inch body lift i was planning on putting on because i got it for next to nothing but now i'm not too sure of the floor's integrity...
