Body Lifts -Noob Question
Discussion in 'The Garage' started by WY_75, Feb 23, 2006.
  1. WY_75
    WY_75 Registered Member
    Dec 27, 2005
    15
    Cody, Wyoming
    Why do the majority of people on this board dislike body lifts? It seems like the opinion of most is to remove them if the blazer/truck already has them, or don't get a body lift in the first place.
    Why?:confused:
    WY_75
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I'm betting it's because some prefer to enlarge the wheelwells (rather than jack the body up) if they need room for larger tires.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Lots of reasons , including keeping a low center of gravity , not having anything stacked that could break or come out , not having to weld extensions or bend anything , no gaps etc .
    Sometimes it can be neccessary , like clearing a doubler without cutting the floor .
    I always liked sky-high trucks growing up , but then I grew up and found out what wheeling was :thumb:
  4. WY_75
    Dec 27, 2005
    15
    Cody, Wyoming
    Thanks for the reply. I just wondered if there was a mechanical reason not to use a body lift. I thought it would help, because I don't want to trim any sheetmetal.
  5. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    I kinda like the idea of a 1" or maybe 2" body lift in the future for my 89 blazer casue i think that it would help on other projects like changing motor or tranny or even clocking the 241 TC. Also the gap between the frame and body could come in use at the truck wash bays to prevent cancer on the floor. The dislikes would be the bumper issue of it not looking right and a bit of fab work needed to have all the linkages and fan shroud and fuel tank hose made to work. Personaly im really leaning towards a 6" BDS lift and a shackle flip in the rear with a 1" or 1.5" body lift. Was thinkin about going 4" springs and 1" body lift too, just for the driveline issues with a 6" lift
  6. RubberFloorMat
    RubberFloorMat 1/2 ton status Premium Member
    Dec 12, 2004
    395
    43
    Oklahoma
    i dont belive in them because:
    unsafe
    ****ty looking
    unsafe
    dont help you wheel
    you always have to modify something to get em to work
    if you cant clear the tires you want to run, you need to run a smaller tire, more SUSPENSION lift, or a new box of sawzall blades.
    clearing a doubler is the only valid reason ive ever heard and then what is it, 1" or so?
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Unsafe??? i have seen many guys on this bored run a 3" body lift for YEARS and beat the hell out of it with no problems.:rolleyes: No its not the besy way to go but they can be useful. more suspension lift you say???? what if i have a great susp setup, flexs good, rides nice, and want bigger tires? cutting has its limits. no body lifts arent rght for every situation but thats complete bull$**** that there unsafe if they are properly installed. werent not talking about using hockey pucks...:eek1: Im only going to be running a 1" body lift but i wouldnt hesitate to run a 2 or 3" if need be.
  8. RubberFloorMat
    Dec 12, 2004
    395
    43
    Oklahoma
    well it was noob asking the question, and the uninformed have a tendancy to buy the cheapist stuff they can get.
    which is unsafe, and anything over 3" is unsafe IMO i dont care who makes it.
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I wheeled one for years when I had 33's... now i am at a good point.... however I am 2" lower than what NJ allows as a max.... so I am going up 2" with a body lift in 1 or 2 months... I NEVER had a problem with them... and will always use them....... $65 for a body lift as I just spent $300 for new 6" front leafs... unless someone wants to trade me for a set of 8" leafs....
    if they were " Unsafe " then the manufacturers would be sued and stop making them......
  10. darenofears
    darenofears Registered Member
    Jan 25, 2005
    47
    Indiana
    they can also be used to put an 80s body on a 70s frame
  11. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    just my .02 cents but some states lift laws go by only frame height so a body lift can help clear a bigger tire while not raising the frame as much. i have run 2 and 3 inch body lifts on several trucks that i beat the piss out of and never once had any type of failure due to the body lift.
  12. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    I run a 2" BL on mine now, it was installed by the PO who never wheeled. Aside from a little trimming I had to do to the bottom of the fan shroud (rubbed just a bit when twisted) I can't complain (anymore).
    If I was to do a rig from scratch now I would use a 1" to minimize the gaps.
    When purchasing a BL get one from a well known company and you should be fine.
  13. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    One thing that is forgotten is how easy they make to work on your truck. On this note however, I do have a 3 inch on mine and Im taking it down to a 1 inch from ord. i relocated my bumpers but they will be gone anyways now, and before I was worried about trimming but Im not afraid of the holy sawzall anymore. I will say that I have gone through about 3 700R4's and eveytime I yanked a tranny I was so glad that lift was on there. Made it real easy to get to the tranny bolts. I dont like the look of big body lifts and I do think they might cause the frame and body to flex a little more than without them. Guess it depends on your needs and wants from your truck. But as far as them being unsafe I have never heard of anyone having a problem with them, providing they were installed correctly. And with my truck although I havent beat on it really really hard I am not exactly easy on my truck, and I have driven many miles on the street with that 3 inch bl and have not had a problem.
  14. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Actually that's a reason to USE a body lift.....
    The heavy parts of the truck (engine, trans, xfer, frame, etc) all stay in the same position relative to CG, and all you move higher is the body itself.
    A spring lift raises ALL of those parts higher including your CG.
    :usaflag:
    I'd rather have a body lift, than lift blocks anyday. :D
  15. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    and when you are doing engine and tranny swaps a bodylift might be the difference btween having to cut/ hammer on your sheetmetal/ tunnel and having the swap fit without frame surgery... and it nicer to bolt then hammer and cut
