Body lifts
Discussion in 'OffRoad Design' started by ihatefords, Dec 15, 2004.
  1. ihatefords
    ihatefords Registered Member
    Nov 10, 2004
    28
    Wyoming
    I already have a 3" body lift and a 2 1/2" suspension. Can sort of clear 38's and want to. what does a 5" body sound like. Crazy but cheap started building it so far am at $15 for metal and probably $20 in bolts. Is it worth it?
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Most states have a maximum 3" body lift. I have seen toyotas with 5" bl over in Florida.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Most body lifts stop at 3". From what I have read anything higher is unstable and not safe.
    .02c
    Burt
  4. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    I don't like anything over about a 2" lift, much less a 5". I would recommend finding a different way to make the tires work. Maybe the sawsall? Or a bit more suspension.
  5. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    Safty First
    It Isnt Safe To Do That . It Isnt Worth It . Puts To Much Stess On Body Bolts. If You Get In A Acident The Body Just Snaps Off The Frame. Buy A 4" Lift To Replace Your 2.5 Thay Are Always On Sale With Shocks For Around 300 Dollers. FRIEND HAS SB TRUCK WITH WORN OUT 4" AND 3" BODY WITH WORN BUSHINGS AND CLEARS 38X12.5X16.5 TSL'S WITH SLIGHT FENDER HIT AT CORNERS.
  6. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    cut-out fender flares! They give you alot of clearance and make your truck look good. I have a 4in suspension, 3in body and I had 38x15.50x16.5s and they had a ton of room!
  7. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Instead of killing yourself and others with booty fab give ORD a call about there 1" Longer HD shackles and a set of "0" Rates. If the 38's still don't fit:hack: . I know it will be more than your $30 body lift but hopefully your life is worth more than that.
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    So if you were to do a five inch body lift, do you also recommend bolting the seats diractly to the frame so that you don't go for a ride in the body down the cliff when the body snaps off? I have visions of Wile E. Coyote.:D
