Body Mount Bolt Removal
Discussion in 'The Garage' started by wfotyme, Dec 13, 2004.
  1. wfotyme
    wfotyme Registered Member
    Oct 29, 2002
    17
    Fresno, Ca.
    I'm in the process of replacing the body mounts on my 74 K5..I've read all the threads..Gained alot of input (thanks) and heard alot of war stories. I just want to know if using an Impact Gun is the best way or if using a breaker bar is the way to go..I've been spraying PB Lube every night for the last week. I'm tring everything I can to not rip up my new carpet..I just finished installing my roll cage and interior..I never thought about the threads breaking loose until I read other peoples war stories.Now I know..So, IMPACT GUN or BREAKER BAR....
  2. zx672
    zx672 Registered Member
    Mar 2, 2004
    48
    Olney, MD
    I just put a 1"ORD body lift and poly bushings on my 84 K5 and 3 out of the 10 mounts gave me hell. Used an impact to take mine out and the other 3 just a lot of patience :grind: :weld: :hack: . Good luck....but the K5 will drive so much better when you are done :D
  3. firejunky
    firejunky Newbie
    Sep 30, 2004
    Memphis Tn
    I used a inpact on my body bolts. I have a 73 k-5, I soaked them with some PB max and about 5 min. later took the inpact and they all came right out. Good luck with everything.
  4. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    If the truck came from a rust area... good luck. They will probably break no matter what you do. Or you might get lucky. I just went with an impact.
    The Blazer I used for my build was a Georgia body and frame. Body bolts were a breeze to get off.
