Body mount bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Texas84K5, Mar 24, 2003.
  1. Texas84K5
    Texas84K5 Registered Member
    Apr 29, 2002
    14
    Weatherford, Texas
    anyone had welded-in body mount bolts (head of bolt welded to floor). What is the best way to remove without replacing sections of floor?
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    grind it flat with the floor on both sides and drill a new hole. Thats what I'd do. Make sure you measure where the hole is before you grind the head off.
  3. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    The rear 4 in the bed area were tack welded to the floor. Took the angle grinder to the welded area, then drilled a hole, slightly larger than the bolt diameter, through the head of the bolt. 2 smacks with a hammer and drift, and they were out.
  4. dyeager535
    26,979
    I just used a dremel to cut through the tack welds, and the bolts came out. Just make sure you get the entire weld broken, or the bed will "rip".
    That's the only place mine (all?) were welded.
  5. Texas84K5
    Apr 29, 2002
    14
    Weatherford, Texas
    I only a few of them are welded. I will post-up once I give it another shot. Thanks for the input.
