body mount condition
Discussion in 'The Garage' started by mccomas, Dec 26, 2003.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    this will give you an idea of what is holding your rig together. this is from an 86 that is super clean with no body or floorboard rust what-so-ever. i did not expect the corrosion to be this bad. it has eaten about 20% of the bolt diameter away...
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I have worse bolts than that /forums/images/graemlins/thumb.gif But I do live on the East Coast /forums/images/graemlins/rotfl.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's nothing compared to what I've seen. Thank god I've got six new cab mounts on mine.
  4. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    mine have got to be much worse im in ontario canada, its gunna be real bad i dont even want to look. (just got truck) guna get a small body lift kit to remady it /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Mine don't look like that....Oh yeah, that is because I replaced all that stuff /forums/images/graemlins/thumb.gif
  6. dyeager535
    26,976
    My core support bolts are the only ones that looked like that. Actually any I take apart up here, those are usually by far the worst.
    When I did my body mounts, I took all of the cup washers that hold the mounts in place, and drilled two holes in each, where the water would gather. (lowest part of the "cup") I ground two small channels from the center to the holes I just drilled, both to allow water to "flow" under the actual body mount cushion. Those things rust out because water gets in them, and with the "seal" at the base of that cupped washer, the water just sits in there.
    Yes, I may be anal, but with poly body mounts, and an almost rust free body, I don't intend, plan or hope to ever have to see those bolts again. /forums/images/graemlins/smile.gif
