body mount nut/ axle placement
Discussion in 'The Garage' started by shaun, Feb 11, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    So I received my shackle flip, zero rates and front springs /forums/images/graemlins/woot.gif. Now I have 2 questions.
    1 One of my body bolts is missing the nut (????????) WHat size is that nut so I can get a new one?
    2 I want to move the front axle foward 1" or 1.5" what steeing corrections would I need to make?
    3 sorry i lied. Is there any benefit to moving the rear axle also??? /forums/images/graemlins/thinking.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Re: body mount nut
    If you're running the stock steering setup, you'll have to shorten your draglink. If it doesn't shorten enough just by turning the sleeve, you may have to cut a bit off of the end of one of the drag-link ends, but it should work. I've never done it, but I'm thinking there's enough thread there to make up the difference of 1 inch.
    No major benefit. The reason to move the front forward is to keep the tires out of the fenders/firewall. If you wanted a specific wheelbase for some odd reason, I suppose moving the rear would be one way to accomplish that. And, moving the rear axle back a bit will increase the departure angle...but probably not enough difference to justify the amount of work/$$ to do so.
