body mount problems
Discussion in 'The Garage' started by Habez, May 8, 2006.
  1. Habez
    Habez Registered Member
    Mar 27, 2003
    45
    Houghton/Frankenmuth, MI
    Over many years of rust, the buckets on my frame, where the body mounts bolt, are pretty much gone. On most of them, the holes are as large as the body mount rubber, or at least what's left of the rubber. What would probably be the best way to fix this problem?
    I am thinking of getting some steel and cutting a plate for the top of each of these and weld this plate to the existing steel the best I can. After cleaning it up of course. I know this idea wouldn't be the strongest, but would it be enough to hold up?
    The other idea I have is get some angle iron, cut it about the size I need, box the sides then bolt them where the old ones are rivited.
    Or better yet, does anyone know if you can just buy these peices?
  2. sweetk30
    Nov 1, 2004
    25,544
    540
    horseheads , ny 14845
    just what i did . look hear.
  3. Habez
    Mar 27, 2003
    45
    how well have those held up? That is pretty much what I was thinking of doing in the first place.
    I'm mainly concerned because I will be wheeling it, but it will also have to be driven on road so safety is a large concern.
  4. sweetk30
    Nov 1, 2004
    25,544
    540
    the plate is the same thickness as the stock frame mount. should hold up the same as stock till the rust eats it off.
