Body mount torque
Discussion in 'The Garage' started by Chevy305, Aug 27, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    What do I torque the body mounts to on my 85 K10?
  2. Teamstatic2001
    Teamstatic2001 Registered Member
    Dec 24, 2005
    92
    Muskegon, MI
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I tightened mine as tight as I could get them. The guy helping me kept saying "that's 275 lbs"........
  4. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
    So should I let my impact wrench loose on them or do it by hand?
  5. Teamstatic2001
    Dec 24, 2005
    92
    Muskegon, MI
    I would do them by hand and make them damn tight, no real torque spec i believe i dont think it really matters just as long and the rubber is smooshed and they are tight enough there not gunna let loose.
  6. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
    Ok I guess I will have whip out my breaker bar and tighten the hell out of them.
    Thanks guys ;)
  7. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    I know this thread is a little older, but one of my cab mounts (K30, single cab) broke the other day. I replaced the old ones with new poly bushings about 3 months ago and tightened them really well.
    Now while offroading the hole in one of the bottom cups teared out (what a bang!!) and the lower mount fell down. Is this because i tightened them too much or couldn't the 22 years old rusty cups just withstand any longer?
    Thanks in advance.
    Walter
  8. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    i'd say probably the cup was deteriorated. mine looked fine and i reused them but there were a couple that came out in pieces when i took the bolts loose to install the body lift. my advice would to just use huge flat washers or find the cups in an LMC book. that's probably what imma do
  9. Cowboy_80
    Cowboy_80 1/2 ton status
    Nov 28, 2006
    1,086
    Mcloud, OK
    can't be too tight. Your body and your engine are supposed to stay where you put them. If it wasn't rust it might have worked loose a little, the free play allowing for more force... My bet would be on rust though.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    An instruction sheet I got way back in the early 90's from Energy Suspension states to torque the bolts to 85 ft. lbs. so there can still be a slight flex.
    All the instructions I've gotten in the later years didn't have any torque readings. So, I'm sticking with 85 ft. lbs.
  11. dieselponyexpress
    Jan 26, 2004
    220
    Germany
    Ok, I will torque them all to 85 ft. lbs., maybe using some locktite on the bolts. The original rubber bushings are way more flexible, even full torqued.
    Thanks again guys!
    Walter
  12. dyeager535
    26,982
    191
    Thought of this thread as I was browsing the '91 R/V manual.
    Core support nuts are 35 ft lbs
    Cab mounts are 55 ft lbs for bolts, 35 ft lbs for nuts.
  13. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    I was looking at the Energy Systems instructions and found this line:
    When all mounts and hardware are installed, torque all bolts to factory
    specifications
    According to the service manual, the body mounts are torqued from 35 to 55 ft - lbs depending on truck model and location.
    For the K5:
    Position #1 - 35 ft-lbs
    Position #2 - 55 ft-lbs
    Position #3 - 45 ft-lbs
    Position #4 - 35 ft-lbs
    Position #5 - 35 ft-lbs
  14. dyeager535
    26,982
    191
    What year service manual? Odd that they threw in the random 45 ft-lbs there. :)
  15. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    1979 Light Duty Truck Service Manual. The listing is a little screwy.
  16. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    That would be a great question for ORD in the vendor section. I'm getting ready to order a 1" body lift, so the information would be good to have.
