body mounting question...
Discussion in 'The Garage' started by 84gmcjimmy, Sep 2, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Heres my question...
    for those who dont remember, I am taking everything off my frame, so I can coat it in a rust inhibitor...
    When I re-mount the tub, should I use ORD body mounts, or should I just solid mount them? I will have a 1" BL with it.
    Someone said with flex and whatnot the body mounts will crack or something? Any help?
    This is going to be on my trail only rig.
  2. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    use poly body mounts with the 1" body lift so you have a little give! /forums/images/graemlins/grin.gif
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I don't know if your serious or not because of the "grin" smiley.
    What does everyone else think?
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you can't have the body solidly mounted to the frame, you need to have some give. you can use rubber or poly bushings, IIRC they are about the same price.
  5. dyeager535
    26,980
    I'd use something softer than solid, for sure.
    There was a huge difference in my truck from stock rubber to poly, (way more body panel twisting) solid would be horrid IMO.
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    solid mounting baaaad, poly mounts goooood.
    j
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay. Thanks... poly it is /forums/images/graemlins/waytogo.gif
