Body Mounting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by B75k5, May 22, 2000.
  1. B75k5
    B75k5 Registered Member
    Mar 5, 2000
    53
    Southern Calif
    Need some feedback on replaceing body mounting on my 75K5.
    Should I stay with Chev parts or use poly parts?
    Any why...Please.
    Thanks in advance. Harry, Southern Ca.
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I've seen an article at Off-road.com, I think, where a guy used poly and didn't like them. Too much noise and vibration. It really depends on what you're gonna do with it. I think rubber would be my choice. I don't need any more noise and vibration in my '74!!
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  3. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    You defenetly should replace them, Which ones to use I dont know but my 88's rubber was half rotten and the bolts had rusted like I would not belive.
    Maybe adding a 2-3" bodylift at the same time? It will be alot of nucklebusting work so be prepared. But it feels better to have replaced those damn bolts....
    [​IMG]<font color=blue>Espen88k5</font color=blue>
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I replaced mine with http://www.energysuspension.com body mount kit and I love it!! If any thing it smmothed out the ride and made it quieter. Of course I whent from only haveing 5 of the 12 mounts still connected to the frame[​IMG] and barly any rubber to 12 solid poly mounts so I did notice a HUGE change!
    The key is to get the poly mounts that are impregnated with polygraphite (black) to prevent poly squeek and also DONOT over tighten them! I would recomend poly to anyone!!
    Good Luck
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  5. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Just cut up some old tires and make new ones....don't use studded tires ....hehehehehehe
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
