body mounts NEED HELP
Discussion in 'The Garage' started by sf_wood, Nov 3, 2005.
  1. sf_wood
    sf_wood Registered Member
    Apr 4, 2005
    70
    san francisco ,ca
    so i just installed new body mounts and 1" lift(ORD) .Now the cab off centered ,how do i re align the cab on the frame. :confused:
  2. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    loosen the bolts jack the body up a little and push it the way it needs to go.
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    1) Have weight just slightly on frame
    2) Use a drift pin or long bolt you can bang and pry with...or a round pry type bar
    3) Using a side to side motion on the steel frame mount move body back and forth as desired... slightly tighten down bolts as you go... should line up pretty easily
    Normally they dont get that far out... if it is you might need to lift off and reposistion using long bolts to capture it on the way down in at least 4 places
    cam
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    And to make sure it's centered correctly put a 2x4 against the side of the tire so it contacts both the bottom and top of the sidewall and measure over to the fender lip. Obviously you want both rears sides to be the same and both fronts to match, but the front won't necessarily match the back.
