Body mounts, ORD lift pucks.***pictures added***
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ntaj*ep, May 20, 2003.
  1. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Just "finished" putting in the poly body mounts, and ORD body lift in the K5. Damn nice ride, well around the block anyway. /forums/images/graemlins/thumb.gif I even took pictures of some of the process, for everyone who has yet to tackle this. /forums/images/graemlins/thumb.gif It was a pain but not too difficult. /forums/images/graemlins/rotfl.gif
    BTW Ryan did you get yours finished up?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Body mounts, ORD lift pucks.
    Congrats that you got it done and it wasn't to hard /forums/images/graemlins/thumb.gif now hurry up and get those pics...even tho i've already done one /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    looks good. /forums/images/graemlins/thumb.gif strange mine still look like your original pics. /forums/images/graemlins/rotfl.gif i gotta get to work. i am gonna do the same when i get home in a month or 2.
    nathan
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    i just took mine all off and re-did them all, i added shims to open my doors up and found that the big washer on the bottom had a 1/2" hole in it and I was bolting a 3/8" nut to them. Found that the nut almost screwed itself through that washer...took them all off and added a 3?8" washer to them all...mine looked like yours when i took them off... /forums/images/graemlins/thumb.gif
  6. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    They were just gross and torn. I just can't believe what a diffrence in ride I have.
    I am missing 2 of the mounts though. Did anyone else do the ORD lift blocks?
  7. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
    What poly mounts did you use? Where did you get them? What did ou pay? How was the quality of the kit and the fit? I am doing the same thing on my 70K5 soon and not sure if I want to do poly or stock rubber. I think I am going with a Performance Accessories 2" body lift. I used one on an S-10 I had a few years ago. It was a nice kit.
  8. brandoneh
    brandoneh 1/2 ton status
    Aug 1, 2002
    179
    Lake Stevens, WA
    What do you think about that bumper sittin way below the body? i put a poly e. 3 inch body lift and i hate the way the bumpers look on it. Any cheap ideas?
  9. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    As far as the mounts go I got them local for about $100 to my door. I really like the poly bushings alot. I have them for my trans. and t-case. Some people don't like how "positive" they feel but I like the feeling. As far as the brand I think they were Pro-thane mounts or something like that.
    Now the bumpers, the rear I had to cut off as it was welded to the frame and hung down too low. The front bumper I just loosened up so the body could move up and around it. Even though I only went a small amount up(1" spacers and new mounts) I will still be relocating the front bumper up a bit more. The rear bumper will be almost the same as my old unit, except it will be thinner and tighter to the body. I really do not like the "big" body lift and low bumper look. /forums/images/graemlins/rotfl.gif
  10. Ryan B.
    Jul 18, 2001
    5,693
    CA
    You talkin to me homes? /forums/images/graemlins/grin.gif
    Yeah, i did my 1" body and all the body mounts a few months ago. /forums/images/graemlins/thumb.gif I had to grind all the factory welds off the heads of the bolts... and found it was easiest just to grind the whole fricken head off the bolt and then use a center punch to punch the bolt out through the bottom. Don't even have to break the nuts loose that way. /forums/images/graemlins/thumb.gif
    Definatly got my $50 worth out of buying a Die Grinder for that job!
    Took me a good day to do the whole job. About 8 hours. Had to remove the radiator to get to the front two bolts and grind the heads off. No doubt the biggest PIA job that i've ever done on my K5. It's a great accomplishment to finally change those original body mounts... I might feel a little more road vibration and bumps, but the body feels a lot more solid on the frame... No more clunking and banging of the body slamming on the frame.
    Replacing all the body mounts on my friends 2nd gen wasn't much fun either. /forums/images/graemlins/ignore.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
  11. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Ryan,
    you happy with the 1" so far or do you wish you would have gone with a 2"
    I know greg has been wanting to bring his back down to a 1".
    Looking for opinions here. I've got a line I think on a 3" for $40
    or my other option is to cut down these 1 3/16 alum pucks I have to fit as body pucks. so I'd be out machining cost on those.
  12. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Ya I'm talkin' to you! /forums/images/graemlins/grin.gif
    Your front most mount bolts were welded???? Damn! The two in the floor pan and back were all welded (rescessed welded bolt heads /forums/images/graemlins/1zhelp.gif) but those two below the rad. had jam nuts. Yes I did have to cut them off as well being that they were stripped and all. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
    I'm waiting for two of my last pucks to arrive and I will be driving around. /forums/images/graemlins/thumb.gif
  13. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Aaron- Ya know now that i think about it, i don't think my front radiator support bolts had a factory weld like all the others, they were more like just rusted in place... I was in the routine of grinding off the heads of the bolts and punching em through, if they gave me much trouble thats what i did next. /forums/images/graemlins/grin.gif
    Les- I like the 1" kit and thats all i'd go with. I was replacing all the body mounts and figured what the hell i'd like a little extra lift. /forums/images/graemlins/grin.gif I wish i greased up the bushings better b/c one of the mounts is making noise... One of these days i'll loosen it up and fix the squeek. /forums/images/graemlins/grin.gif
    I don't like body lifts like 2" or 3", it looks tacky with the bed way off the frame. My friend has a 3" and wants to get rid of it all together or just go 1". /forums/images/graemlins/k5.gif /forums/images/graemlins/pimp1.gif
  14. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    1" body is /forums/images/graemlins/pimp1.gif
