Body Mounts
Discussion in 'The Garage' started by daleearnhardt01, Apr 25, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Went down to Uwharrie this weekend and blew 2 body mounts out. What happened was the bottom washers were a bit rusty and the bolts pulled through. Anybody know where I can get those washers that the mount sits in?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Wait...when those big washers rust off, you're supposed to replace them. /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/smirk.gif
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    They are like $3 each at LMC I just ordered 6 /forums/images/graemlins/whistling.gif
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Well they didnt break until I started climbing some rocks so thats why Im replacing them... /forums/images/graemlins/wink.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/doah.gif
    Hey Jeremiah what about the thing that is on top of the mount that looks like a cup that kinda goes over the rubber? Do they get rusty enough to replace, only reason I ask is I know you know rust.. /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    I've not replaced one yet. I use the torch and burn the old rubber out and give them 83 coats of paint /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
    The bottom ones do rust into pieces though /forums/images/graemlins/whistling.gif
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    So the metal is attached to the rubber? I have new poly mounts so I guess Ill have to do what you did and burn the old junk out. What about the two back pairs, should I order some stuff to be on the safe side as far as metal stuff goes? You can tell me LMC part numbers if you want.
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I just pryed the bushing out of the upper part with a couple big screw drivers, then the chuncks that where left I heated up and scraped them out.
    Here a pic of the upper mount and the new bushing
    you need the upper mount pad because it has an oblong hole in the middle... thats why the polys have that big hole
