Body Mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dave_90_blazer, Mar 30, 2005.
  1. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    Who sells new body mounts?
    I need to replace the ones in my 90, when I get twisty, the trans goes into neutral :confused:
    I"m thinking of doing a body lift at the same time, but not sure, what is needed to keep the cooling fan lined up to the shroud?
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    IIRC LMC has them. i think they have both the frame end and the body portion. in the end i think it would cost less to fabricate new ones and stronger as well.
    edit, do you mean the bushings? or the moutns and the bushings... well, Summit has the bushings at a better price than LMC normaly. ORD may even beat the summit price. also you could check with the local parts guys. urethane or rubber.... i would go urethane personaly. stiffer ride, but lst a lot longer
    Grant
  3. dave_90_blazer
    Jan 1, 2004
    688
    the bushings, and thanks
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I get Prothane bushing kits from JC Whitney. cheapest I have seen. I hate body lifts. But if your gonna do one, I'de stay in the 1-2" range. I use 1" just for a "little" clearance. But that way nothing really gets misalligned. I just "trim" the bottom of the shroud to clear the fan.
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Get OEM ones from the stealership... urethane makes my kidneys hurt. Urethane ones transmit everything to the cab... it reminds me of riding in a unibody car where all you hear is road noise and you pray for good shocks.
