Body Mounts
Discussion in 'The Garage' started by tremor, Jul 10, 2005.
  1. tremor
    tremor Registered Member
    Mar 20, 2004
    10
    CT
    Rusty '85 Blazer. What kind of body mounts have people liked or disliked?
    How hard are they to change? I have a forklift if the body has to come off the frame but I'd really like to avoid that if possible.
    Thanks,
    Steve
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    use a porta power to lift the body off the frame.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its not that complicated, soem floor jacks and certain pieces of lumber will do it, can even do it by self if plan it right, aint hard
    block the wheels good though
    good luck
  4. CheyenneKid
    CheyenneKid Registered Member
    Jan 12, 2003
    41
    Body Mount Advice
    I've swapped in body mounts and a "NHL Body Lift" in a 2wd suburban. The hardest part is getting the rusty bolts out of your body. You can do one side at a time, loosening the bolts with the body supported by a couple of jacks or concrete blocks and shim lumber. There is a surprising amount of play between the body and the frame, and torque the mounts until they start to compress. Just be carefull! Good luck,
    The Kid
  5. tremor
    Mar 20, 2004
    10
    CT
    Thanks for the tips. Am I better off with stock mounts or aftermarket?
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    depends, rubber ride better IMO. They absorb more road vibration. However, poly last longer. They absorb less vibration, but are generally a good upgrade over rubber. Rubber are cheaper than poly. Figure out what is more important to you and go from there. I replaced mine w/ rubber since I wanted to reduce vibration into the body.
