body mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yunit, Jul 9, 2001.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I have a set of body mounts that were suppose to originally go on my 78', but now I have a newer truck and I am replacing the rear floor and decided it might be a good time to replace the mounts since they are destroyed. My question is will mounts from a 78 work on an 87', I compared mount to mount and everthing looks the same, height and width. Is it possible to use these mounts on my newer truck and how do you feel about body lifts? Thank, Pete.
    1987 Jimmy Sierra Classic, Palisades Park, NJ 07650
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I don't know why they wouldn't work if they're the same size and everything .......... a lot of guys on here don't care for the body lift but I kind of like them, I'll be putting on a 2" when I get to my project like yours.
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  3. Heavymetal
    Heavymetal 1/2 ton status Premium Member
    Mar 30, 2001
    936
    Oregon
    You might want to check the diameter of the the hole in the frame mount. I did something similar, tried to put 87' rubber mounts in an 77' frame. The diameter on the 87's were to big to fit in the 77' frame. This was on a suburban though, your application may be different.
    Mike.
    77' 3/4 ton Burb, 400cu, sm465, np205, 14boltff, dana44, 4.10s, 36 inch cepeks.
  4. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    I've got a 3" Trailmaster bodylift and had no problems with it but fun installing at the back mounts.
    <font color=green>Joe Angelicchio
    <A target="_blank" HREF=http://community.webshots.com/user/jangelicchio>http://community.webshots.com/user/jangelicchio</A>
    Lisle, Ontario, CANADA</font color=green>
  5. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    the only problem I've had with the body lift in my 87 is that I can't get into 1st gear.. the linkage for the trans got screwed up because of the lift. I wouldn't go to extremes like my 3" body lift without going to a cable shifter first
    <A target="_blank" HREF=http://billybob87k5.50megs.com>Homepage of Porky & Stinky</A>
    Billybob, the REAL <font color=red>Bionic Redneck</font color=red>
