Body mounts
Discussion in 'The Garage' started by 1tonjimmy, Apr 6, 2007.
  1. 1tonjimmy
    1tonjimmy Banned
    Jan 27, 2007
    22
    Maryland
    I need to replace 3 or 4 body mounts on my gmc jimmy, anyone know where to get OEM replacements? or possible upgraded mounts? im sure ill need new pucks as well.
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    LMC Truck (http://www.lmctruck.com) has both the OEM design mounts and the Polyurathane kit from Energy Suspension.
    Both good kits.
  3. 1tonjimmy
    1tonjimmy Banned
    Jan 27, 2007
    22
    Maryland
    ahhh yea i forgot about them :D thanks!
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
  5. dyeager535
    26,980
    I'd get energy. Last I priced them, they were cheaper than rubber.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yea summit has that kit for $62, i think thats what im going to go with
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    get the poly mounts they will last longer and are cheaper.
  8. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    THe only problem is with the poly mounts you dont get all the new harware and what not that comes with the LMC kit. LMC rubber mounts keep more vibration out of the cab too. There are trade-offs either way. I think Rubber is better for the cab mounts for the comfort factor. It takes them a LONG time to wear out. By the time the do wear out you wont mind replacing them again. Our trucks are all about 20 years old and most on original rubber bushings.
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I got all new hardware with my poly bushing kit when I did one on my burb right after it got it, but that was 6 yrs ago.
  10. dyeager535
    26,980
    If you can tell the ride difference poly vs. rubber, in one of these trucks, you've got a well-calibrated rear. :)
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im going to go ahead and order that body mount kit by energy susp from the summit link i posted. so nothing is needed to the bed portion on the truck? it just sits on the frame right?
