body mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ducati-cooter, Jan 26, 2002.
  1. ducati-cooter
    ducati-cooter Registered Member
    Jan 24, 2002
    78
    Madison WI
    I am installing a prothane polyurathane body busing kit in my 90 k5 jimmy. I can't figure out with one goes were. I know the original rear mounts are square but I have all round mounts and there are many different ones with the kit.
    PLEASE HELP !!!!!!!!!!!!!
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I don't know the answer to that question,but I am going to replace my body bushings soon...and wanted to ask if you are taking any pic's of the install? Also run into any other problem's?
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>The darker side of nonsense...</a>
  3. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    I installed Daystar mounts on mine. The instructions were pretty clear, though. The kit replaces the original square mounts with the round mounts, so don't worry about the fact that the new ones are all round. What problems are you having? Do the instructions indicate 1st postion, 2nd position, etc?
    <font color=red>"DON'T TAKE LIFE TOO SERIOUSLY, YOU WON'T GET OUT ALIVE."</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  4. UseYourBlinker
    Jun 7, 2000
    11,117
    So far on prices this is what I found:
    ORD $95
    Energy Suspension $80
    How much do the Daystar's run for? Any difference's in the diff. kit's?
    Eric
    from Freekmont,CA.
  5. UseYourBlinker
    Jun 7, 2000
    11,117
    Chris, How did it go today?
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>Freedom is a state of mind...</a>
  6. ducati-cooter
    Jan 24, 2002
    78
    Madison WI
    well it went shitty I didn't get the body mounts done because I was to busy fixing the steering column and trying to figure out why the engine wouldn't fire up.
  7. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Don't know if this will help but take a look at the lmc catolog and see if you can match them up that way just my 2 cents-later mike
  8. dyeager535
    26,976
    I'd say, as long as you aren't doing a body lift, match them up, using the originals, in the stock location, to match with the new ones, or as close as possible, since stock old ones are probably a bit thinner than new.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  9. ducati-cooter
    Jan 24, 2002
    78
    Madison WI
    I would match lem up but I am missing some of the originall ones. I am missing the rubber portion and the steel washet that was under the bolts. I E-mailed prothane but I don't think I will get a response right away so I will call them in the morning and try to get some info.
  10. 73 K5 Blazer
    73 K5 Blazer 1/2 ton status
    Sep 14, 2001
    483
    Madison, MS
  11. ducati-cooter
    Jan 24, 2002
    78
    Madison WI
    My bushings that are in my kit look nothing like those and I had already looked at them. I called prothane today and the tech department said I can't help you with this, that is an old kit and we never broke down the install pics back than like we do know. I am going to try and return them today and order some from another shop or ord.
