body mounts
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by farmer dan, Mar 15, 2002.
  1. farmer dan
    farmer dan Newbie
    Feb 23, 2002
    mich
    DOES ANYONE KNOW IF YOU SHOULD REPLACE THE BODY
    BUSHINGS BEFORE YOU START REPLACING ROCKERPANELS,PILLERS, OR FLOOR PATCHING AND SHOULD YOU HAVE THE DOORS ON ? NEED HELP THANKS !
  2. wrath
    wrath 1/2 ton status
    Mar 4, 2001
    182
    Grayling,Michigan
    I would suggest you replace your bodymounts if there junk,they will throw your alignments off on your door gaps if bad..Just a reminder, when I did my outer rocker,I had my drivers door on and off about 6 times before the final weld..test fit,test fit,test fit...when doing your floor it would prolly be wise to have the top on also..Good Luck
  3. Crushergmc
    Crushergmc 1/2 ton status
    Mar 17, 2001
    181
    Oregon
    Definitly a better way. But, I will probably replace mine without the new mounts. What I will do is weld a brace from the dash to the bed at the door jam, take of the door then go to town.
