Body mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Oct 10, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    How hard is it to change out the body mounts on my K5? They aren't rusted-damn I love Texas, but they look pretty deteriorated. Thanks
    90K5
  2. stephan van leir
    stephan van leir 1/2 ton status
    May 4, 2000
    181
    central Colorado
    If they are not rusted they should be easy to change out. You will need a small grinder to cut the tack welds on the rear carriage bolts. Use a good poly kit! This is not an area to try to say a few bucks. I would recomend Offroad Designs 1" body lift, because it gives a slight lift and also contains new hardwear that you will need anyway. Just be sure to do one side at a time.
  3. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Go with ORD or with Energy Suspension urethane. I used Energy Suspension after I tried Prothane. The Prothane kit for the Blazer does not fit the Blazer. ES kits fit like a champ. Instructions come with the kit are easy to follow.
  4. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    I am wondering this too.Both my mounts(washers) under both my doors on both sides are gone=(.These things are welded?!
    I want to replace my mounts but i dont think i wanna go with the energy ones.I've heard they feel "hard".I have a 100 mile round trip just for work and want my truck to ride nice.The energy ones do last forever though...later
    89 almost 3/4 ton sub,almost
    One From None
  5. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Changing them aint hard at all. But, don't go with using the ORD 1" body lift as the mount. B/c the mounts come in different sizes. Like the ones at section # 3 of your truck are longer than rest. (This pertains to my 75', your 90' may be different). Plus remember, there are mounts under the mounts too and you can't use the ORD puck for them. But anyway, the 1" ORD body lift block is made out of aluminum, and the Energy Suspesion is made out of Polyurethane. The poly, although hard, gives more cushion than the aluminum puck. Rubber obviously keeps the softest ride, but won't last nearly as long. I myself went with Energy Susp, and the 1" ORD lift. Check out my site for the write up. Good luck.
    Boss
  6. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    I just replaced all of the body mounts on my blazer and I couldn't tell much difference in the "hardness" of the ride, and the ones that were on my truck were completely shot!! Some of them weren't even there anymore!! It did however make my bodylines much better and there aren't as many rattles coming from it anymore either. The ES set is the one I got and I really like it. Just be sure to grease the bushings good or they will squeak.
    HTH
    Buddy
    I've got my dream truck and it's a 72 K-5 that is getting there!!
