Body mounts
Discussion in 'OffRoad Design' started by keith, Jan 18, 2001.
  1. keith
    keith 1/2 ton status
    La Fayette, GA
    I called the other day and asked a few questions about this and went and done some investigating. Seems the only difference in the 79 and 86 body supports is the size and shape of the hole. The 79 has a round hole where the 86 has a slightly larger hole but with flat spots on the side. The question now is I have the 79 1" body lift and the bushings. If i make the holes match I will need the 86 bushings. Will I need to change the body lift too?I guess what I'm asking is the actuall body bushings thicker on the 86's? ( do I need longer bolts)
    79 Blazer 6"lift 35's locked/4:56 <A target="_blank" HREF=http://www.keith.coloradok5.com>http://www.keith.coloradok5.com</A>
  2. Stephen
    Sep 15, 2000
    Carbondale Colorado
    I'm not sure what you're going to need, luckily, the bolts are just common 1/2" coarse thread, so you can buy what you need at a hardware store. The pucks from our kit are the same. I think you're going to have to get into the project and measure the bolt lengths you need and go from there. Sorry I'm not more help, just haven't done anything like this.
    Making the world better, one truck at a time.
