Body off resto/cleanup
Discussion in 'The Garage' started by BowtieRed, Feb 12, 2004.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Ok, I think i've decided I'm just going to take it down to the frame, and sand that down, give it a few coats of POR17, replace what i find broken, pull the tranny/t-case and sandblazt the both and paint them. (when i painted them in my install i left some dirt on so it's coming off) i REALLY wish i had a sandblaster that i could use for the frame, but the beadblaster i have access to is a contained one. anyway for all the wires from the body to the frame i think i'll just clip thme and get some plugs, to speed the rebuild process up. any ideas/tips? i might even have the body painted while it's off.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No reason to clip the wires, they come apart in big pieces by un plugging them.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    if you're using POR-15 dont sandblast your frame. and if you do decide for some reason to blast it, and then coat it with POR, do yourself a favor and leave it sit outside exposed to the elements for a month or so. enough for it to get a good coat of rust on it. POR is moisture curing, so it will draw the moisture out of the rust, stopping it in its tracks, and making the finish harder. you dont have to worry about the finish of the metal you're preparing, because POR lays out very smooth. BTW, one coat should be more than sufficient.
  4. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Sounds good, I always like a guy that trys to keep everything in good shape.
    I don't know about blasting the t-case and tranny, I wouldn't wan't sand getting inside somehow, it's pretty darn fine sand that you have to use.
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    You can have them soda blasted your trany and t-case..... There isn't any resudue left and it cleans just as well as sand blasting except not as harmfull.....
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i'd be avoiding the tailshaft housing altogether and probably avoid the bellhousing too then take it off and beadblast it seperately.
  7. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I disagree on needing to wait on the frame. I sandblasted my frame, then used POR's Marine Clean, then their Metal Ready before I POR-15'ed my frame. I did 2-3 coats of regular POR-15 and then a coat of their Chassis Black. My frame came out excellent. Pics here: http://community.webshots.com/user/douglasgrant I set up a booth in my garage by hanging plastic sheeting. Then I got a cheap small fan and used cardboard to vent it while I shot it. I bought a sandblaster from Sears for less than $100 and I've used it many times over already. I also did my Corp14ff with it and several other parts. It was a worthwhile investment.
  8. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Nice pics of the clean up...but you shackles are on upside down /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    You know, I was wondering why the tires stuck up so far in the wheel wells............ /forums/images/graemlins/histerical.gif
