Body Panel Replacement!!! WOOHOO!!!
Discussion in 'The Garage' started by Big Red, Aug 24, 2004.
  1. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    ok, so here goes. gonna buy all new fenders/door shells/bedsides/tailgate. if i go to LMC they have them all (ofcourse all hafto be trucked to me DOH!!) so. anyone delt with them before? is the truck frieght $100 per item or order? anyways, back to the subject. what does it take to redo the bedsides? i look at where they join the cab and it looks like they're welded to it. im assuming this is true. so that means i would hafto cut them apart and re-weld the new sides in place? i also plan on redoing my whole floor. so i know im gonna be busy with that for a while. thanks again guys!
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have oredered several small and medium sized stuff from them. all went well. But the bigger stuff? I have never ordered big parts from them. truck freight can get expensive. If you are using aftermarket parts, which a bedside will be, you might be able to get them locally, cheaper than truck freighting. If you truck freight them in and their damaged, thats pretty much your fight. I deal with a place called Keystone auto supply. for all my fenders and doors. I can get new fenders for 95.00 each. Inner fenders for 40.00 each aftermarket gates for 195.00 doors for 80.00. They have a dealer in hartford.
    ]keystone-auto.com
    I am getting a cowl induction hood from them for 375.00
    I am doing the same stuff with my 89. The back half of the bedsides unbolt. they are spotwelded on the door jamb, along the b pillar, also on the inside of the b pillar, on the back side. Then there is a small "flap" that is spot welded at the top, were the roof connects. A snap on 5/16 spot weld drill will make EASY work of the spotwelds.
  3. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    I did just that, floorboards, rockers, rear quarters, front fenders outer and inner, tailgate, doors, radiator support, grill and all light fixtures.
    I also used LMC for many of the interior dash pieces, steering wheel, center console, window regulators, A/C pieces, winshield wipers and washers, battery boxes, and chrome trim.
    They were GREAT to work with.
    /forums/images/graemlins/pimp1.gif
    Fred
  4. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    kewl thanks guys. ok, so some minor welding to do. thats kewl. i clicked the link and it no worky. o well. i'll search for them later. thanks again guys! /forums/images/graemlins/peace.gif
  5. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
  6. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    thanks for the link, but half the links on the page are blank and u can't tell what they are. but thanks anywho!
  7. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    The links i've been putting up are for a nation auto body supply company. I tried to link you to the "locater" page as they have a dealer in the Hartford CT area.
    they are keystone auto body supply
    www.keystone-auto.com
