Body people here please help with Trim Removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Krase, Mar 25, 2003.
  1. Krase
    Krase Registered Member
    May 19, 2002
    90
    Northeast ,Tennessee
    Ok Guys and Ladies, can anyone give me pointers on removing the side trim off the blazer, its the chrome version, i had one piece fall off and went to pull the next piece off and chipped my paint a bit, since i do not offroad much i try and keep my blazer looking sharp in my eyes, anyway does anyone know any tricks to removal of these and how to get glue off easily. Lastly what do you recommend to "restore" paint underneath, will wax alone do it?
    Thanks for any help,
    Todd
  2. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    where there plastic or metal clips under the other pice or is it the stick on kind? /forums/images/graemlins/k5.gif
  3. jwingfield2k
    jwingfield2k Registered Member
    Jan 29, 2003
    29
    Richardson, Texas
    heat gun will melt the glue, then just peel it off, or on a warm day you can set it in the sun and also use a hair drier.
  4. Krase
    May 19, 2002
    90
    is the stick on kind
  5. ed1507
    Jan 25, 2003
    70
    indiana
    you might try a orange style degresser or wd40 i know a company called zepp makes a orange gel we use to remave decal glue might try looking them up ed
  6. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Like the other guys said, use a heatgun. Remember that the rearcorners are usually bolted on, so don't try to just pull them off.
  7. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Depending on if you have some of the bad paint years, you can use 3M Adhesive Remover. It is safe to use directly on paint, however, if you are in the bad paint years it might actually take some of the paint off. I used this to remove the body moulding on my old truck and it worked pretty good, just took a lot of elbow grease. A couple of appications loosens up the adhesive and you can generally roll it off with your fingers.
  8. Mr.LaHoyaSunset
    Mr.LaHoyaSunset Registered Member
    Jan 25, 2003
    88
    Columbus Ohio
    what pieces are still intact, or are you putting them back on? a few of mine are mia, and id like to get em back on....
    if your interested in selling em, that would be really cool.
    Colin in Ohio /forums/images/graemlins/thumb.gif
  9. Khi5in
    Khi5in Registered Member
    Mar 19, 2002
    46
    Medford Massachusetts
    try 3m adhiesive remover doesn't hurt the paint. I've only seen this in body supply stores though.
