Body swap question...
Discussion in 'The Garage' started by grimjaw, Nov 17, 2006.
  1. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Is there any real difference between 2wd and 4wd bodies and beds? I am thinking of buying a clean 1985 1/2 ton 2wd longbed truck and moving the body and bed to the 1986 K30 I have. I just want to make sure, this time, I will have no surprises with this.
    Thanks for your input.
  2. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    Beds should be identical.
    The kicker in the cab is the tranny hump... 4WD's, IIRC, are larger/taller.
    I gather you'll hafta either massage the 2WD hump with a BFH, or use a body lift, plus of course cut the hole for the transfer case shifter.
    I *think* the humps in those years are either integral or at least spot-welded in place, as opposed to the older ones which are bolted in.
    You could cut out the 4WD hump and graft it into the 2WD cab. :dunno:
    -- A
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Dremu is correct, only difference is the tranny hump
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    A 2wd will have the high-hump it it was a 4spd truck. Some 2wd autos got a high-hump also, but that may only have been late crewcabs. Not sure if any std. cabs got that treatment.
  5. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    i just did this. on a 87 cab to 79 k30. 2" body was about perfect.
  6. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    im putting an 86 cab onto my 79 and its already on a 77 chassis, 4wd to 4wd would be easiest, but the only problem you may have is the rear cab mounts and a trans hump
