Body swap questions
Discussion in 'The Garage' started by mlaux, Aug 25, 2006.
  1. mlaux
    mlaux 1/2 ton status Premium Member
    Oct 22, 2000
    141
    9
    Rigby, ID
    My buddies 78 is badly rotted. He has located a good 82 body and wants to swap it. Will the body mounts and wiring harness be the same between these two?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    there will be some differences, the front clips are totaly different between thoes two years, the wiring will probley take some work to make it all go together. other than that it should not be to bad
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Even though the body change happened they are very similar. I did a swap from a 79 pickup to an 82 and it was really easy.
  4. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Does the '78 have rear seat floor pan for the passenger's feet. Some of the older trucks the rear floor rises up right behind the front seats. Newer trucks, the floor rises up under the rear seat.
    If the rear floor rises up under the rear seat on the '78, the body swap won't be a problem. Otherwise the frame and body mounts will be a little different.
  5. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    When I did my body swap (80 to a 82 Blazer) I used the wiring harness from the 80 because I knew it was good and had no idea what was up with the new one. It really isn't hard to swap especially if you are doing something as big as a body swap it should be no problem.
