body swap - suburban to pickup
Discussion in 'The Garage' started by idislikeunc, Nov 2, 2004.
  1. idislikeunc
    idislikeunc Registered Member
    Oct 27, 2003
    25
    Raleigh, NC
    I'd like to swap a pickup cab onto my 1990 suburban frame (1/2 ton 4wd). Will an '87 cab fit? Can I use a 2wd cab? Anyone ever done it?
    thanks, Paul
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have never heard of anyone doing it to a burb, but many have done it to a blazer. you most likely will have to make the rear cab mount for the pickup cab. other than that, it should work fine.
    get some pics also /forums/images/graemlins/waytogo.gif
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I know someone putting a S10 on a burb frame, but not a full size truck body. I think that the mounts will be different.
  4. diesel4me
    Jul 24, 2003
    17,566
    942
    Massachussetts
    I've helped build a few pickups with a suburban chassis--you need to rob the rear cab to frame mounts from the pickup frame,and bolt them in the correct spot after you put the cab in place and line up the front cab mounts(they line up fine with the truck cab).The wheelbase is different on a suburban,and the rear frame is slightly longer,and its not the exact same bends as a pickup frame--its a chore to put a pickup bed on a suburban frame--the body mounts on the burb are in the way,and you have to make holes in the frame for the bed.The 2 trucks I worked on were mainly for off road use only,we put a long flatbed on both to carry firewood in log lengths--another guy I now found it easier to just saw off /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif the suburban behind the drivers door,and put the back wall of a pickup cab on it,and make it a flatbed.They haul a lot of wood! /forums/images/graemlins/crazy.gif
  5. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    you want pics? front cab mounts will line up fine. rear cab mounts will have to be fabbed. i can get any pics you need. i have an 88 obs cab on my 75 burb frame.
