body swap!
Discussion in 'The Garage' started by blaub85, Oct 12, 2006.
  1. blaub85
    blaub85 Newbie
    Oct 12, 2006
    illinois
    i have a 89 blazer and the body is trashed and i was wondering if i took another older k5's body and put it on would everything line up ok even if its a 2 wheel drive i've heard both that it would be ok and that it wouldn't line up
    thanx
    bryce
  2. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    thats fine as long you can find a body from a 81 to 91..... older body styles from 73 to 80 wont fit since there are differences in frame design and body mount locations
  3. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    also make sure the frame isnt kinked first before moving on
  4. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    I replaced mine. It was a 80 and I replaced it with an 82. The Major difference was whether or not it was an airconditioning one or not. The AC model has a different firewall opening that if you don't have ac will have to bechanged. The windshield wipers are different pre 81 and up. The frames and mounts were the same. The hood was different. Pretty much everything just mounted up.
