Body Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by buknbronco78, Dec 6, 2001.
  1. buknbronco78
    buknbronco78 Registered Member
    Sep 28, 2001
    13
    Wayne, NJ (passaic county)
    Found a 1975 K5 with a fully rebuilt drivetrain but swiss cheese body. Is there any bodies that will swap without changing body mounts and other stuff that isnt easily changed like drivetrain placement. Thanks in advance.
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    If I remember correctly, the full convertible top K5s have a different body than the rest. The difference is where the floor comes up behind the drivers seat. Someone correct me if I'm wrong. There may be other body mounts that don't line up also.
    <P ID="edit"><FONT class="small">Edited by rampage on 12/06/01 01:29 PM.</FONT></P>
  3. 73 K5 Blazer
    73 K5 Blazer 1/2 ton status
    Sep 14, 2001
    483
    Madison, MS
    I have a 73 blazer and I think the only difference is the bracing behind the rockers. The body from a newer blazer should be a straight swap.
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I just swapped the rear half of a 73 onto my 81 Jimmy...I had to hand build some new body mount points on the frame to make it work.
    Pics of the swap below...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I believe it is 1973 up to 1980 will bolt up to the same mounts.
    The last two mounts on the frame are the same from 73 to 91.
    The mount in front of the rear seat is the same from 73 to 77 , 78 to 80, but just uses a different body bushing. However the 81 to 91 body mount AND bushing are different.
    the mount under the front floor is the same just uses a different bushing. The front mount in the core support is a different mount and bushing.
    If you really have the time and are patient you can swap any body on to the frame [​IMG]
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
