body swapping????
Discussion in 'The Garage' started by mud390, May 22, 2003.
  1. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I know this sounds crazy, but would a 3 + 3 cab (crew cab) fit on a 77 blazer frame? I know it would look funny as all get out, but I don't wanted to be limited to 3 people in truck cab. I'm sure that mounts would have to be fabricated and all that good mess, but I'm more worried about the physical dimensions. Just a thought. Am I crazy for having this thought?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    no. the frames are to different. The blazer frame curves up after the front seats. and the 3+3 cab needs a straight frame.
  3. mud390
    Oct 31, 2002
    1,210
    I thought the frames on the pre 79 or 80 model blazers where flat, relatively anyway. Mine seems to be fairly flat. Maybe a body 2 ro 3 inch body lift would correct the difference.
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    If you did pull that off I think it would be awesome!
  5. mud390
    Oct 31, 2002
    1,210
    Does anyone have the dimensions of the 3 + 3 (crew) cab? I might just have to break out the old measuring tape to see if this might work.
  6. dyeager535
    26,982
    191
    Probably going to be real close to the Suburban measurements right past the rear doors. Not a whole lot of 3+3's running around!
