Body weight
Discussion in 'The Garage' started by Roostr84, Sep 26, 2002.
  1. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    I was curious about the hybrids you see with a compact truck on a fullsize frame and running gear. What I am wondering is are the differences in body weights alone between a fullsize cab and bed vs. a compact cab and bed that significant?
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Hmmm...
    Hardtop=190 lbs
    doors are about 80-90 lbs each=180lbs
    The rear bed section from the doors back is roughly 350 lbs. My friend and I manhandled the bed section I spliced onto my truck into the back of a rental van.
    Tailgate is roughly 100lbs
    front fenders are about 25 lbs each=50lbs
    Hood is about 80-90 lbs
    All told that puts the body at about 950-1000 lbs. How much heavier than a mid size pick up body is your guess...I'd say you might save 350 lbs max.
    The only reason I'd swap a smaller body on is for width...not weight.
    Rene
  3. NCblackandredk5
    NCblackandredk5 1/2 ton status
    Nov 12, 2001
    149
    Chapel Hill, NC
    i have some friends with a s10 body on a blazer frame... the body didnt even push the frame down when we set it on there... id would guess its quite a bit lighter
  4. Roostr84
    Aug 19, 2000
    451
    NJ
    The topic actually came up in a discussion between myself and a friend. Neither of us could really say though we were refering to pickups more than k5's vs. blazers. I just figured someone on here has some insight into it. Thanks for the replies fellas.
  5. Grim-Reaper
    7,385
    Atlanta
    My guess on the full body with top and interrior...about 2,000 pounds. 2 guys can lift the cab of stripped out mini truck without much problem. I would say you could loose and easy 1,500 or so with a mini cab and front clip if you tried. Once you get a roll bar and other gear back on with 1 ton running gear, 38's you would probably end up with a truck that's about 4400l-4600lb trail weight. A k5 with full cage and hard top and 1 ton gear and 38's I'm sure is in the 5600-6k range for trail weight. There is a scale up the road I'll try and run my truck over it and see what it weighs if it's open on the weekend.
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I had a stock S-10 Blazer that scaled at 4200 lbs, my Jimmy scaled at 5700 with all my trail junk and a full tank of fuel.
    For comparison a friend has a YJ that scaled 4100 with trail junk, full tank and driver.
    Getting a K5 under 5000 lbs would be tough to do, especially with one ton diff's.
    Rene
