Body work, help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 74k5inVA, Oct 10, 2002.
  1. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    how do i replace this piece?
    any info please, TIA
  2. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    Buy the post from LMC and splice it in. /forums/images/graemlins/crazy.gif
  3. 74k5inVA
    Dec 13, 2001
    329
    Virginia Beach, VA
    is that what they are calling cab corners?
  4. COLLISION
    May 15, 2002
    175
    Sorry man,
    I just looked in the LMC catalog and I dont see that part.
    It should be called a "B" pillar or lock pillar, GM part# is 347115(discontinued), try napa or another supplier in your area. If you can't get the part then you'll have to cut out the exising one, beyond the area thats already been welded, and just make a new piece of metal to fit in the hole.It would be best to weld a backing plate in so you have at least 1" of overlap for strength.
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Check any body shops in your area also. They might have the pillar laying around. JcWhitney might have it.. /forums/images/graemlins/tongue.gif
  6. COLLISION
    May 15, 2002
    175
    I'm pretty sure that a post off a 73-77 p/u truck will be the same, maybe look into that. Gives you more options if you try finding a used one.
