body work on lower doors
Discussion in 'The Body Shop' started by mini_mull, Apr 14, 2005.
  1. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I know the bottom section of my doors are going to need some body work when I get my paint done. From where the factory molding used to be down they are not straight, but a little bumpy and uneven, though not too bad. My question is, how does the body shop do this kind of work, pound on the sheetmetal or filler? Is it going to be expensive? Would it be cheaper to look for some perfect replacement doors? Thanks in advance.
  2. personaltrainer
    personaltrainer 1/2 ton status
    Nov 4, 2004
    178
    Atlanta GA
    good luck with "perfect" replacement door for a reasonable price. GM still sells them (if you can find them) for about $500 each OR you could get some crash parts for about $150 each but they are horrible. I looked at some new crash parts today and decided against it. I'll be rumaging through the junkyards once again!
    The bodyshop would likley just sand and put some body filler in it to smooth it out, unless of course, the dents are deep enough to warrant having to pull them out then smooth it. Not sure if I helped at all - just my .02.
    ps. I've been door hunting myself all day!!!
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I had the same problem...on one of my doors...
    It had a bullet hole...and about 50 digs...
    I welded up the hole...then put a coat of bondo over the whole door below the door handle. :cool1:
    But it depends on the size of the digs...you may have to hammer/dolly. ;)
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you could just a new door skin and put that on
  5. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Thanks for the info, guys. Looks like filler, new doors, or doorskin. What's doorskin? I would guess it's the top layer of sheetmetal on the door, but do you cut off the old and weld in new or what?
