Body work, what disk to use for griding with Right angle grinder
Discussion in 'The Garage' started by jjlaughner, Feb 24, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I have rust spots like this
    I used this pad, fairly agressively!
    And all the more I could get to come off was like this
    I'm not wanting perfect but is there a good grinding disk I can use to knock this off without removing too much metal. I plan on repainting but I'm not to worried about flat spots.
  2. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    I used a disk just like that one to do bodywork on mine, not rust, just to grind down weld i put on, it worked good, just grind it down to just below factory body metal line, and then glaze it with either bondo or glazing putty... just my 2 cents.
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I think that by the time you get rid of the rust there will be no metal left. I would cut it out and weld in a patch. Other than that just go buy a more aggresive grit disc.
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    looks like somebody doesn't have to work today /forums/images/graemlins/rolleyes.gif
    try a DA sander with an 80 grit pad.
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Actually...it needs sandblasting!!
    If you don't remove the rust from inside the pits...
    it will be back!!!
    If blasting isn't possible....
    I'd hit-it with #40 grit grinding disks....
    dent-it in a little....
    then apply some duraglass over it.... /forums/images/graemlins/smile.gif
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I do have a sandblaster, Problem is the air compressor is not here, its at the other house. I need to sand blast/bead blast some other things to paint also! /forums/images/graemlins/smirk.gif
    One of these days I will have all my $hit together /forums/images/graemlins/rotfl.gif
