Body Work
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, May 19, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I had a collision awhile back and it messed up the quarter-panel. I think I'm going to just replace it. My question is do you have to cut the thing out with a torch or is it just a bolt-on operation? thanks
    <font color=green>Money</font color=green>--&gt;Blazer
  2. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    You'll have too cut the old panelout too replace it.I would use a cut off wheel of some sort.Sometimes the heat from a torch will distort the metal making it even more of a bitch.
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    First buy the new panel, then size it up before cutting. make sure there is an over lap between the old and the new. They make a pair of channel locks you can get at J.C.Whitney's that will bend a 1/4 inch indentation in the edge of the existing panel so that when you lay the new panel on top of it it will lay flat and leave you something to weld to. The inclosed attachment is way out of proportion, but I think you will get the idea...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  4. ED70K5
    ED70K5 1/2 ton status
    Apr 28, 2000
    179
    Texas, USA
    What do you think of buying panels from JC Whitney catalog?? The price is right for a new set of rocker panels for my K5.
  5. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    if you want a bit heaver panel , get them from LMC, otherwise the ones from Whitney are alright, I have used them, no problem...
    2B1ASK1
