Bodymounts
Discussion in 'The Garage' started by wayne, Jun 4, 2006.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Going to do poly mounts on the 90 this week. Any tips on what to do or not to do? Bolts will be sprayed with PB before hand. I am not doing a body lift, just mounts.
  2. dyeager535
    26,982
    191
    Do a search for a couple of posts, the only real hassles IMO (unless you've got rust) are the fuel tank ones and the bed ones.
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    pretty much what Dorian said. loosen up all the bolts to the last thread, pick up the drivers side w/ a jack and a block of wood, change mounts, put bolts back in and one thread on the nuts...repeat on pass side. tighten. the rear ones were a pain for both me and HispanicPanic. ended up having to cut them, but you have to do it fron the inside. might have to drop the tank.
